Ga door naar hoofdinhoud
Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Cover: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Cover: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Cover: stap 1, afbeelding 3 van 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  2. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: stap 2, afbeelding 1 van 1
    • Use screwdriver to remove screws.
  3. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: stap 3, afbeelding 1 van 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  4. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: stap 4, afbeelding 1 van 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  5. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Sliding Lens Cover: stap 5, afbeelding 1 van 1
    • The front sliding lens cover.
  6. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: stap 6, afbeelding 1 van 2 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: stap 6, afbeelding 2 van 2
    • Remove four screws using Phillips located on the inside of the front cover.
  7. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: stap 7, afbeelding 1 van 2 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: stap 7, afbeelding 2 van 2
    • Remove front sliding lens cover.
  8. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: stap 8, afbeelding 1 van 2 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: stap 8, afbeelding 2 van 2
    • The front sliding lens cover is now removed and may be repair or replaced.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Stephannie Allen
255 Reputatie
10 handleidingen geschreven
Clemson, Team 13-1, Benson Spring 2013 Lid van Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 1,201
