Ga door naar hoofdinhoud
Sony Cyber-shot DSC-T9 Front Cover Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-T9 Front Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 Front Cover Replacement: stap 2, afbeelding 1 van 1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 Front Cover Replacement, Front Cover: stap 3, afbeelding 1 van 3 Sony Cyber-shot DSC-T9 Front Cover Replacement, Front Cover: stap 3, afbeelding 2 van 3 Sony Cyber-shot DSC-T9 Front Cover Replacement, Front Cover: stap 3, afbeelding 3 van 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 Front Cover Replacement: stap 4, afbeelding 1 van 1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 Front Cover Replacement: stap 5, afbeelding 1 van 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 Front Cover Replacement: stap 6, afbeelding 1 van 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Stephannie Allen
255 Reputatie
10 handleidingen geschreven
Clemson, Team 13-1, Benson Spring 2013 Lid van Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 389
