Ga door naar hoofdinhoud
Sony Cyber-shot DSC-T9 CCD Module Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-T9 CCD Module Replacement, Battery: stap 1, afbeelding 1 van 1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 CCD Module Replacement: stap 2, afbeelding 1 van 1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: stap 3, afbeelding 1 van 3 Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: stap 3, afbeelding 2 van 3 Sony Cyber-shot DSC-T9 CCD Module Replacement, Front Cover: stap 3, afbeelding 3 van 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 CCD Module Replacement: stap 4, afbeelding 1 van 1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 CCD Module Replacement: stap 5, afbeelding 1 van 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 CCD Module Replacement: stap 6, afbeelding 1 van 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 CCD Module Replacement, CCD Module: stap 7, afbeelding 1 van 1
    • This is the CCD module.
  8. Sony Cyber-shot DSC-T9 CCD Module Replacement: stap 8, afbeelding 1 van 1
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  9. Sony Cyber-shot DSC-T9 CCD Module Replacement: stap 9, afbeelding 1 van 1
    • Remove CCD module.
    • You may have to tug on the ribbons to remove the CCD module.
  10. Sony Cyber-shot DSC-T9 CCD Module Replacement: stap 10, afbeelding 1 van 1
    • The CCD module is now removed from the camera.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Stephannie Allen
255 Reputatie
10 handleidingen geschreven
Clemson, Team 13-1, Benson Spring 2013 Lid van Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 827
