Inleiding
This guide will teach the user how to disassemble and access the AV port for replacement or installation.
  1. The battery cover is located on the right side of the camera.
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Ensure that the battery lines up properly with the slot in the camera.
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. This is the camera without the front cover.
    • This is the camera without the front cover.
  4. Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  5. Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are. Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are. Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  6. Pull apart the inner hardware from the back case by prying on the left side. Pull apart the inner hardware from the back case by prying on the left side. Pull apart the inner hardware from the back case by prying on the left side.
    • Pull apart the inner hardware from the back case by prying on the left side.
  7. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  8. Remove the back cover.
    • Remove the back cover.
  9. The back cover is now removed from the internal hardware.
    • The back cover is now removed from the internal hardware.
  10. This is the CCD module.
    • This is the CCD module.
  11. Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • Use plastic opening tool pop open the two ribbons attaching to the CCD module.
    • These are the two ribbons.
  12. Remove CCD module.
    • Remove CCD module.
      • You may have to tug on the ribbons to remove the CCD module.
  13. The CCD module is now removed from the camera.
    • The CCD module is now removed from the camera.
  14. These two screws hold in the AV port. Use Phillips screwdriver to remove screws.
    • These two screws hold in the AV port.
    • Use Phillips screwdriver to remove screws.
  15. Remove metal screw plate.
    • Remove metal screw plate.
  16. Use pry stick to pop off ribbon.
    • Use pry stick to pop off ribbon.
  17. Remove AV port from camera.
    • Remove AV port from camera.
Conclusie
Stephannie Allen
189 Reputatie
10 handleidingen geschreven
Clemson, Team 13-1, Benson Spring 2013 Lid van Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 8
Altijd: 374
