Inleiding
By following 4 easy steps, you will be able to open the camera, locate the tripod receptacle, and replace it.
Wat je nodig hebt
Remove all seven black 4 mm Philips #00 screws holding the front panel into place. Two on each of the sides of the camera and three on the bottom.
Remove the one sliver 4mm Philips #00 screw that is holding the receptacle in place near the bottom of the camera.
Remove the tripod receptacle by simply lifting it out with your hands or with tweezers if necessary.
