Ga door naar hoofdinhoud
Sony Cyber-shot DSC-T500 LCD Screen Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Case Screws: stap 1, afbeelding 1 van 2 Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Case Screws: stap 1, afbeelding 2 van 2
    • There are 4 screws total holding the outer shell of the camera. One on each corner. To reach the bottom two, you have to slide the camera cover up. Vise versa for the top two.
    • Make sure to remove the battery before taking the camera apart.
  2. Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Back Panel: stap 2, afbeelding 1 van 2 Sony Cyber-shot DSC-T500 LCD Screen Replacement, Remove Back Panel: stap 2, afbeelding 2 van 2
    • Separate the front and back housings carefully.
    • Be careful not to pry it apart as they are connected together by the LCD ribbon cables.
    • Once you have separated the two housings unplug the LCD ribbon cables.
    • There should be three. One big one and two small ones
    • Remove the LCD screen from the housing.
    • You'll have to carefully lift the internal components of the camera in order to remove the LCD screen.
Conclusie
Chelsea Vitone
213 Reputatie
2 handleidingen geschreven
UWT Liner: Group 4 Lid van UWT Liner: Group 4
Community
6 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 522
