1. Locate the cover on the bottom of the camera.
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
    Voeg opmerking toe
  2. Carefully remove the exposed battery.
    • Carefully remove the exposed battery.
      • If it is difficult to remove, flip over the camera and the battery will slide out.
    Voeg opmerking toe
    • Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
    Voeg opmerking toe
    • Pull the two halves of the camera apart.
    • Place the two halves down with the insides facing you.
    Voeg opmerking toe
    • Find the two clips holding the motherboard to the black lens box.
    • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
    Voeg opmerking toe
    • After releasing the clips, pull out black lens box.
    Voeg opmerking toe
    • Use the plastic opening tool to flip the clip.
    Voeg opmerking toe
    • Grab the white part and slide it to the right until it clicks.
      • This may require some force.
    • Pull out the flash.
    Voeg opmerking toe
    • Use the plastic opening tool to release the clips.
    Voeg opmerking toe
    • Flip the motherboard unit over.
    Voeg opmerking toe
    • Pull the ribbon to separate the motherboard unit from the camera case.
    Voeg opmerking toe
    • Use the #00 screwdriver to remove the 3mm screw located inside the white plastic piece.
    Voeg opmerking toe
    • Remove the white plastic piece.
    Voeg opmerking toe
    • Use the #00 screwdriver to remove the 3mm screw.
    • This is the back of the motherboard unit.
    Voeg opmerking toe
    • The only thing holding the motherboard in are stationary clips.
    • Move the motherboard back and forth until it is loose and can be released from the motherboard unit.
    Voeg opmerking toe
    • You are left with the motherboard unit (on the left) and actual detached mother board (on the right).
    Voeg opmerking toe
Conclusie
Rosario
24 Reputatie
3 handleidingen geschreven
Cal Poly, Team 7-35, Maness Spring 2012 Lid van Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 Leden
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 5
Altijd: 507
