Ga door naar hoofdinhoud
Sony Cyber-shot DSC-T1 Motherboard Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-T1 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Cyber-shot DSC-T1 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 Motherboard Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: stap 3, afbeelding 1 van 3 Sony Cyber-shot DSC-T1 Motherboard Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: stap 3, afbeelding 2 van 3 Sony Cyber-shot DSC-T1 Motherboard Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: stap 3, afbeelding 3 van 3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 Motherboard Replacement, CCD Sensor Module: stap 5, afbeelding 1 van 2 Sony Cyber-shot DSC-T1 Motherboard Replacement, CCD Sensor Module: stap 5, afbeelding 2 van 2
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Grasp the CCD Sensor Module and remove it.
  7. Sony Cyber-shot DSC-T1 Motherboard Replacement, Flash Module: stap 7, afbeelding 1 van 3 Sony Cyber-shot DSC-T1 Motherboard Replacement, Flash Module: stap 7, afbeelding 2 van 3 Sony Cyber-shot DSC-T1 Motherboard Replacement, Flash Module: stap 7, afbeelding 3 van 3
    • This camera houses a very strong capacitor (the black cylinder). Avoid touching anything around the two wires coming out of the top. Doing so will risk serious electric shock.
    • Carefully disengage the internal components from the casing by lifting at the bottom end and giving a gentle tug.
    • The components are still connected to the casing via cables, but they are much more maneuverable.
    • The flash module is shown on the right hand side.
  8. Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 8, afbeelding 1 van 2 Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Use the tip of a spudger to flip up the tab on the ZIF connecter securing the motherboard ribbon cable.
    • Grasp the flash module by the bottom and remove it.
  9. Sony Cyber-shot DSC-T1 Motherboard Replacement, Motherboard Assembly: stap 9, afbeelding 1 van 2 Sony Cyber-shot DSC-T1 Motherboard Replacement, Motherboard Assembly: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to slide the white piece on the back of the back cover to the right.
    • This will dislodge the white piece, allowing you to remove it from the back cover.
  10. Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Remove the ribbon cables from these two ZIF connectors.
  11. Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 11, afbeelding 1 van 2 Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Lift the motherboard assembly up and rotate it so you can easily see where the internals connect to the back cover.
    • Remove the ZIF connectors from the clamp on the left end of the top piece.
    • The motherboard assembly is now separated from the back cover.
  12. Sony Cyber-shot DSC-T1 Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 1
    • Locate the screw inside the small white piece on the motherboard assembly.
    • Remove this 2.9mm screw using a PH00 screwdriver.
  13. Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 13, afbeelding 1 van 1
    Koop
    • Use tweezers to remove the small white piece from the motherboard assembly.
  14. Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Turn the motherboard assembly over.
    • Use a spudger to open the ZIF connector on the motherboard.
    • Remove the ribbon cables from the opened clip.
  15. Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 15, afbeelding 1 van 2 Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 15, afbeelding 2 van 2
    • Pry the motherboard slightly apart form the motherboard assembly.
    • Be careful while separating the board so that you do not damage the ribbon cables or other components.
    • Disconnect the ribbon cable connecting the battery pack to the motherboard.
  16. Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 16, afbeelding 1 van 3 Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 16, afbeelding 2 van 3 Sony Cyber-shot DSC-T1 Motherboard Replacement: stap 16, afbeelding 3 van 3
    • Pull the motherboard up from the battery pack and flip the motherboard assembly over.
    • Use a PH00 screwdriver to remove the 2.9mm screw connecting the speaker to the battery pack.
Conclusie
iDeleted
2.101 Reputatie
39 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 2,491
