Ga door naar hoofdinhoud
Inleiding
Taking out the LCD is one of the more difficult things to do on your Cyber-shot. Because the LCD is located at the back of the camera you will have to take apart the entire camera just to reach it.
Onderdelen
Geen onderdelen opgegeven.
  1. Locate the battery door at the bottom of the camera. Press down on the door and  slide it back.  The door will pop open.
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Remove the battery from the door that you opened in the previous step.
    • Remove the battery from the door that you opened in the previous step.
  3. There are two screws on the left and right sides of the camera, and two screws on the bottom. Use a PH00 screwdriver and remove the six 2.9mm screws. Use a PH00 screwdriver and remove the six 2.9mm screws.
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Use hands to gently pry the front casing away from the camera. Use hands to gently pry the front casing away from the camera.
    • Use hands to gently pry the front casing away from the camera.
  5. Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable. The second picture shows what these tabs look like in their open positions.
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Grasp the CCD Sensor Module and remove it.
    • Grasp the CCD Sensor Module and remove it.
  7. Use tweezers to slide the white piece on the back of the back cover to the right. This will dislodge the white piece, allowing you to remove it from the back cover.
    • Use tweezers to slide the white piece on the back of the back cover to the right.
    • This will dislodge the white piece, allowing you to remove it from the back cover.
  8. Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • Remove the ribbon cables from these two ZIF connectors.
  9. Lift the motherboard assembly up and rotate it so you can easily see where the internals connect to the back cover. Remove the ZIF connectors from the clamp on the left end of the top piece.
    • Lift the motherboard assembly up and rotate it so you can easily see where the internals connect to the back cover.
    • Remove the ZIF connectors from the clamp on the left end of the top piece.
    • The motherboard assembly is now separated from the back cover.
  10. Use a PH00 screwdriver to remove the 2.9 mm phillips screw on the upper left side of the case. Use a PH00 screwdriver to remove the 2.9 mm phillips screw on the upper left side of the case.
    • Use a PH00 screwdriver to remove the 2.9 mm phillips screw on the upper left side of the case.
  11. Remove the back frame from the LCD assembly. Turn the LCD assembly over and gently pull the top bar off (which has the shutter and power buttons).
    • Remove the back frame from the LCD assembly.
    • Turn the LCD assembly over and gently pull the top bar off (which has the shutter and power buttons).
  12. Pull the tape off that holds the LCD to the assembly.
    • Pull the tape off that holds the LCD to the assembly.
Conclusie
iDeleted
2.101 Reputatie
39 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 3,785
