Ga door naar hoofdinhoud
Sony Cyber-shot DSC-T1 Flash Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-T1 Flash Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
  2. Sony Cyber-shot DSC-T1 Flash Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
  3. Sony Cyber-shot DSC-T1 Flash Replacement, Flash: stap 3, afbeelding 1 van 3 Sony Cyber-shot DSC-T1 Flash Replacement, Flash: stap 3, afbeelding 2 van 3 Sony Cyber-shot DSC-T1 Flash Replacement, Flash: stap 3, afbeelding 3 van 3
    • Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
  4. Sony Cyber-shot DSC-T1 Flash Replacement: stap 4, afbeelding 1 van 1
    • Pull the two halves of the camera apart.
    • Place the two halves down with the insides facing you.
  5. Sony Cyber-shot DSC-T1 Flash Replacement: stap 5, afbeelding 1 van 1
    • Find the two clips holding the motherboard to the black lens box.
    • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
  6. Sony Cyber-shot DSC-T1 Flash Replacement: stap 6, afbeelding 1 van 1
    • After releasing the clips, pull out black lens box.
  7. Sony Cyber-shot DSC-T1 Flash Replacement: stap 7, afbeelding 1 van 2 Sony Cyber-shot DSC-T1 Flash Replacement: stap 7, afbeelding 2 van 2
    • Use the plastic opening tool to flip the clip.
  8. Sony Cyber-shot DSC-T1 Flash Replacement: stap 8, afbeelding 1 van 2 Sony Cyber-shot DSC-T1 Flash Replacement: stap 8, afbeelding 2 van 2
    • Grab the white part and slide it to the right until it clicks.
    • This may require some force.
    • Pull out the flash.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Paul Elrich
33 Reputatie
2 handleidingen geschreven
Cal Poly, Team 7-35, Maness Spring 2012 Lid van Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 720
