Ga door naar hoofdinhoud
Sony Cyber-shot DSC-P9 Lens Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-P9 Lens Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Lens Replacement: stap 2, afbeelding 1 van 1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Lens Replacement: stap 3, afbeelding 1 van 2 Sony Cyber-shot DSC-P9 Lens Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Lens Replacement, Outer Casing: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-P9 Lens Replacement, Outer Casing: stap 4, afbeelding 2 van 2
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Lens Replacement: stap 5, afbeelding 1 van 2 Sony Cyber-shot DSC-P9 Lens Replacement: stap 5, afbeelding 2 van 2
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Lens Replacement: stap 6, afbeelding 1 van 2 Sony Cyber-shot DSC-P9 Lens Replacement: stap 6, afbeelding 2 van 2
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Lens Replacement: stap 7, afbeelding 1 van 1
    • After the casing is removed, the camera should look as shown.
  8. Sony Cyber-shot DSC-P9 Lens Replacement, Lens: stap 8, afbeelding 1 van 2 Sony Cyber-shot DSC-P9 Lens Replacement, Lens: stap 8, afbeelding 2 van 2
    • Dislodge the round casing from the lens.
    • Pull it away from the rest of the camera.
  9. Sony Cyber-shot DSC-P9 Lens Replacement: stap 9, afbeelding 1 van 1
    • Unscrew the two 4.0mm Phillips #000 screws from the display.
  10. Sony Cyber-shot DSC-P9 Lens Replacement: stap 10, afbeelding 1 van 1
    • Pull the two ribbon cables out of their slots on the back circuit board.
  11. Sony Cyber-shot DSC-P9 Lens Replacement: stap 11, afbeelding 1 van 1
    • Remove the three 4.0mm Phillips #000 screws holding the back panel in place.
  12. Sony Cyber-shot DSC-P9 Lens Replacement: stap 12, afbeelding 1 van 3 Sony Cyber-shot DSC-P9 Lens Replacement: stap 12, afbeelding 2 van 3 Sony Cyber-shot DSC-P9 Lens Replacement: stap 12, afbeelding 3 van 3
    • Work the back panel out from under the small grey clip.
    • Slide the back panel off of the camera by dislodging it from the remaining clips.
    • Below is a flat, orange cable connecting the lens to the motherboard.
    • Be careful not to bend the back plate during this process.
  13. Sony Cyber-shot DSC-P9 Lens Replacement: stap 13, afbeelding 1 van 1
    • Turn the camera over so that you can see the front of the lens.
    • Two connectors link the lens to the motherboard.
    • Gently bring the lens away from the camera.
  14. Sony Cyber-shot DSC-P9 Lens Replacement: stap 14, afbeelding 1 van 1
    • Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
    • Be careful not to exert too much force, as the connectors are delicate.
  15. Sony Cyber-shot DSC-P9 Lens Replacement: stap 15, afbeelding 1 van 3 Sony Cyber-shot DSC-P9 Lens Replacement: stap 15, afbeelding 2 van 3 Sony Cyber-shot DSC-P9 Lens Replacement: stap 15, afbeelding 3 van 3
    • Gently pull out the cables and move the lens away from the rest of the camera.
    • You should now have two distinct, separate components.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sean Sayles
7 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-25, Amido Spring 2012 Lid van Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 1,352
