Ga door naar hoofdinhoud
Sony Cyber-shot DSC-P9 LCD Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-P9 LCD Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 LCD Replacement: stap 2, afbeelding 1 van 1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 LCD Replacement: stap 3, afbeelding 1 van 2 Sony Cyber-shot DSC-P9 LCD Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 LCD Replacement, LCD: stap 4, afbeelding 1 van 1
    • Unscrew the four 3.0mm Phillips #000 screws holding the back case onto the camera; there are two screws on top and two on the bottom.
  5. Sony Cyber-shot DSC-P9 LCD Replacement: stap 5, afbeelding 1 van 2 Sony Cyber-shot DSC-P9 LCD Replacement: stap 5, afbeelding 2 van 2
    • Pull the back case gently away from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 LCD Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 3.0mm Phillips #000 screws holding the display to the metal backing.
  7. Sony Cyber-shot DSC-P9 LCD Replacement: stap 7, afbeelding 1 van 2 Sony Cyber-shot DSC-P9 LCD Replacement: stap 7, afbeelding 2 van 2
    • Unlatch the display by sliding it towards the circuit board.
  8. Sony Cyber-shot DSC-P9 LCD Replacement: stap 8, afbeelding 1 van 1
    • Remove the two ribbon cables attached to the circuit board by gently pulling them out of their slots.
    • Be careful not to rip the ribbon cables while disconnecting them.
  9. Sony Cyber-shot DSC-P9 LCD Replacement: stap 9, afbeelding 1 van 1
    • The LCD is now separated from the camera.
Conclusie
Jenna Crawford
50 Reputatie
3 handleidingen geschreven
Cal Poly, Team 17-25, Amido Spring 2012 Lid van Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 886
