Ga door naar hoofdinhoud
Inleiding
This guide is used for taking apart the case to fix many of the issues of the Sony Cybershot DSC-P52.
Onderdelen
Geen onderdelen opgegeven.
  1. Sony Cyber-shot DSC-P52 Outer Case Replacement, Outer Case: stap 1, afbeelding 1 van 1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 Outer Case Replacement: stap 2, afbeelding 1 van 1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 Outer Case Replacement: stap 3, afbeelding 1 van 1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 Outer Case Replacement: stap 4, afbeelding 1 van 1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 Outer Case Replacement: stap 5, afbeelding 1 van 1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 Outer Case Replacement: stap 6, afbeelding 1 van 1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 Outer Case Replacement: stap 7, afbeelding 1 van 1
    • Pull the ribbon cable out.
Conclusie
Trevor
277 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-43, Regan Winter 2011 Lid van Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 Leden
20 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 470
