Inleiding
The LCD should be checked if the screen is blank or broken.
  1. Open the battery compartment and remove the batteries.
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Open the memory card compartment.
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
    • Open the case as shown.
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
    • Pull the ribbon cable out.
    • Unclip the ribbon cable shown the in picture.
    • Some ribbon cables do not have a clip holding them in.
    • Remove 7 Screws to remove plate and expose LCD screen.
    • Remove LCD plate to expose LCD components and ribbon cables
    • Check connection of LCD to cables
    • If cables are intact, disconnect cables and replace LCD with new part
    • Repeat steps in reverse order to reassemble the camera
Conclusie
Mark
13 Reputatie
1 Handleiding geschreven
Cal Poly, Team 3-43, Regan Winter 2011 Lid van Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 Leden
10 handleidingen geschreven
Één commentaar
I don’t know the cause of my camera not turning on.
Smgmc64 Productions - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 2,281
