Ga door naar hoofdinhoud
Sony Cyber-shot DSC-P52 Flash Unit Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-P52 Flash Unit Replacement, Outer Case: stap 1, afbeelding 1 van 1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 Flash Unit Replacement: stap 2, afbeelding 1 van 1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 Flash Unit Replacement: stap 3, afbeelding 1 van 1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 Flash Unit Replacement: stap 4, afbeelding 1 van 1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 Flash Unit Replacement: stap 5, afbeelding 1 van 1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 Flash Unit Replacement: stap 6, afbeelding 1 van 1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 Flash Unit Replacement: stap 7, afbeelding 1 van 1
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 Flash Unit Replacement, Motherboard Assembly: stap 8, afbeelding 1 van 1
    • Remove all six screws on the front side of the motherboard circled in the picture.
    • Pull the motherboard from the rest of the housing.
    • It will still be connected to the flash unit.
  9. Sony Cyber-shot DSC-P52 Flash Unit Replacement: stap 9, afbeelding 1 van 1
    • Remove the cable on the back side of the motherboard.
  10. Sony Cyber-shot DSC-P52 Flash Unit Replacement: stap 10, afbeelding 1 van 1
    • Detach the ribbon cables shown.
    • Careful! Touching the leads of the large yellow capacitor can result in a painful shock.
    • Remove the flash unit from the motherboard.
  11. Sony Cyber-shot DSC-P52 Flash Unit Replacement, Flash Unit: stap 11, afbeelding 1 van 1
    • Discharge the yellow capacitor attached to the flash unit by shorting the leads with a screw driver.
    • Avoid touching the leads with your hands, as this can result in a painful shock.
  12. Sony Cyber-shot DSC-P52 Flash Unit Replacement: stap 12, afbeelding 1 van 1
    • Replace the flash unit.
Conclusie
Trevor
295 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-43, Regan Winter 2011 Lid van Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 1,790
