Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
First locate the appropriate screws for detachment.
Remove the five screws shown using a Phillips #00 Screwdriver.
Using a spudger, carefully pry open the front casing.
Carefully separate the front casing from the camera body.
Using tweezers, gently pull the ribbon trace out of its housing found on the left side of the flash.
Using a spudger, pry the small latch between the lens and the flash open to release the flash.
Pull the flash away from the camera.
