Ga door naar hoofdinhoud
Sony Cyber-shot DSC-P100 Camera Flash Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: stap 1, afbeelding 3 van 3
    • First locate the appropriate screws for detachment.
  2. Sony Cyber-shot DSC-P100 Camera Flash Replacement: stap 2, afbeelding 1 van 1
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Camera Flash Replacement: stap 3, afbeelding 1 van 1
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Camera Flash Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-P100 Camera Flash Replacement: stap 4, afbeelding 2 van 2
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  5. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Camera Flash: stap 5, afbeelding 1 van 2 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Camera Flash: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using tweezers, gently pull the ribbon trace out of its housing found on the left side of the flash.
  6. Sony Cyber-shot DSC-P100 Camera Flash Replacement: stap 6, afbeelding 1 van 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement: stap 6, afbeelding 2 van 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement: stap 6, afbeelding 3 van 3
    • Using a spudger, pry the small latch between the lens and the flash open to release the flash.
    • Pull the flash away from the camera.
Conclusie
Katie McCraw
191 Reputatie
7 handleidingen geschreven
Clemson, Team 1-5, Benson Spring 2012 Lid van Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 2,724
