Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two screws from the top of the camera.
Remove the two screws from the bottom of the camera.
Remove the rear cover of the camera.
Peel the strip of the black padding off of the screw.
Remove the screw.
Lift the right side of the screen up, then pull the screen to the right to free the LCD screen.
Carefully pull on the ribbon cables to disconnect them.
