Inleiding
This guide will show you the steps to remove and replace the lens of the camera
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Place the device so bottom of the camera is facing up .
Remove the five marked screws with a Phillips #000 screwdriver.
Insert the spudger where arrow marks to gently remove the lower panel.
Use the plastic opening tool with a prying motion to remove the side cover of the camera.
Remove the small screw under the multi/USB cover.
Use the plastic opening tool to remove the button board.
Remove the ribbon cable connecting LCD display to camera sensor and battery housing.
Press on the lens with your finger.
Gently pull the lens container out of the camera.
6 andere personen hebben deze handleiding voltooid.
4 Opmerkingen
Aside from a few missed screws, very nicely done. And I suspect that if one didn’t realize the need to remove those screws, sh/e probably shouldn’t be attempting the job in the first place. :) (I noted the comments after completing lens removal.)
Can you comment where/specifically the missing screws that were not listed can be found? Any other guides out there that are more comprehensive?
Eric C -
