Ga door naar hoofdinhoud
Sony Cyber-shot DSC-HX90V Button Board Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: stap 1, afbeelding 3 van 3
    • Remove the marked screw with a Phillips #000 screwdriver.
    • Remove the marked black M1.4 X 3.5 Phillips head screws
    • Use the spudger to gently remove the lower panel.
  2. Sony Cyber-shot DSC-HX90V Button Board  Replacement: stap 2, afbeelding 1 van 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: stap 2, afbeelding 2 van 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: stap 2, afbeelding 3 van 3
    • After removing the marked black M1.4 X 3.5 Phillips head screws with the Phillips #000 screwdriver on the side panel, using the spudger where the red arrow marks, insert and gently remove the side panel from the device.
    • From either corner of the button board gently use hands to remove the button board.
  3. Sony Cyber-shot DSC-HX90V Button Board  Replacement: stap 3, afbeelding 1 van 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: stap 3, afbeelding 2 van 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • After the outer black panel case of button is removed, gently disconnect the control board data cable to the motherboard utilizing the tweezers gently where the red arrow marks.
    • Ribbon wires can easily be damaged.
Conclusie
Marin Rusinov
853 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 26
Altijd: 2,009
