Inleiding
If viewfinder is broken or is not working properly you can follow these steps to replace it for a new one. These steps can also help in replacing shutter button and flash. For this guide you will need a PH000 screwdriver, a plastic tool opener, metal spudgers and a magnetic mat or plastic bag.
Wat je nodig hebt
Before disassembling any part of the camera, turn off power by pressing down on the ON/OFF button. The ON/OFF button is located on top of the camera.
Use the plastic opening tools included in the iFixit tool kit first. If the shell/parts do not detach from each other, use metal spudger (from iFixit tool kit) to loosen/separate the plastic shell of the camera. Keep in mind there may be more screws holding parts together. Work delicately and separate sides evenly.
Look for the screws located on the circuit board. These screws are what allow the thin golden film/plastic ribbon to connect the top piece to the rest of the camera.
Remove circuit board screws by using the PH000 Phillips head screwdriver. Place the two 0.4 mm silver Phillips screws on magnetic mat or plastic bag.
2 opmerkingen
Hi, what is the part number(viewfinder)?
I would love it if someone could add a little piece here to show how to replace the flash unit as well.
