Ga door naar hoofdinhoud
Sony Cyber-shot DSC-HX300 View Finder Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-HX300 View Finder Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 View Finder Replacement: stap 2, afbeelding 1 van 1
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 View Finder Replacement: stap 3, afbeelding 1 van 1
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 View Finder Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-HX300 View Finder Replacement: stap 4, afbeelding 2 van 2
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: stap 5, afbeelding 1 van 3 Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: stap 5, afbeelding 2 van 3 Sony Cyber-shot DSC-HX300 View Finder Replacement, View Finder: stap 5, afbeelding 3 van 3
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Philips head screws holding the plastic camera housing together. They are located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down and remove the remaining 3 (4 cm) Phillips head screws holding the plastic housing together.
  6. Sony Cyber-shot DSC-HX300 View Finder Replacement: stap 6, afbeelding 1 van 2 Sony Cyber-shot DSC-HX300 View Finder Replacement: stap 6, afbeelding 2 van 2
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 View Finder Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 View Finder Replacement: stap 8, afbeelding 1 van 2 Sony Cyber-shot DSC-HX300 View Finder Replacement: stap 8, afbeelding 2 van 2
    • Remove the 1 (2 cm) Phillips head screw
    • Remove the 2 (5 cm) Phillips head screws that mount the View Finder to the camera.
    • Carefully disconnect the ribbon wire that connects the View Finder to the Motherboard.
  9. Sony Cyber-shot DSC-HX300 View Finder Replacement: stap 9, afbeelding 1 van 2 Sony Cyber-shot DSC-HX300 View Finder Replacement: stap 9, afbeelding 2 van 2
    • Gently pull the plastic View Finder off of the metal mounting bracket.
  10. Sony Cyber-shot DSC-HX300 View Finder Replacement: stap 10, afbeelding 1 van 1
    • The replacement View Finder can now be installed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Elizabeth Surface
1.465 Reputatie
9 handleidingen geschreven
USF Tampa, Team 4-6, Meier Fall 2015 Lid van USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 1,162
