Ga door naar hoofdinhoud
Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 2, afbeelding 1 van 1
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 3, afbeelding 1 van 1
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 4, afbeelding 2 van 2
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: stap 5, afbeelding 1 van 3 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: stap 5, afbeelding 2 van 3 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
  6. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 6, afbeelding 1 van 2 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 6, afbeelding 2 van 2
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 8, afbeelding 1 van 3 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 8, afbeelding 2 van 3 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 8, afbeelding 3 van 3
    • Carefully remove the 7 ribbon wires connected to the mother board.
    • Remove the 2 (5 cm) Phillips head screws on the speaker mounting bracket.
    • Remove the 3 (4 cm) Phillips head screws that secure the motherboard to the camera.
    • Lift up on the speaker mounting bracket to remove it.
  9. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 9, afbeelding 1 van 2 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 9, afbeelding 2 van 2
    • Carefully disconnect the ribbon wire connecting the HDMI port to the Motherboard.
    • Once the Motherboard is removed the replacement can be installed.
  10. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, HDMI/USB port: stap 10, afbeelding 1 van 1
    • Remove the 3 (4 cm) Phillips head screws securing a mounting bracket over the HDMI/USB Port.
  11. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 11, afbeelding 1 van 1
    • Lift up on the mounting bracket to remove the HDMI/USB Port from the camera.
  12. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: stap 12, afbeelding 1 van 1
    • Once the HDMI/USB Port is removed the replacement can be installed.
Conclusie
Elizabeth Surface
1.465 Reputatie
9 handleidingen geschreven
USF Tampa, Team 4-6, Meier Fall 2015 Lid van USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 1,554
