Inleiding
To replace the flash on your device you are going to have to take quite a bit of pieces out.
Wat je nodig hebt
Orient the device so the bottom is facing up, and the lens is facing you ("bottom view").
Remove the black M1.4 X 3.5 Phillips head screw in upper right corner of the device.
Service manual for reference: Click to go to the service manual.
Discharge the capacitor by connecting the resistor jig between the highlighted squares.
