Ga door naar hoofdinhoud
Sony Cyber-shot DSC-HX100V Viewfinder Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-HX100V Viewfinder Replacement, Viewfinder: stap 1, afbeelding 1 van 1
    • Make sure camera is turned off.
    • Press the ON/Off button to turn off the camera.
    • WARNING: Data may be lost if the camera remains on.
  2. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: stap 2, afbeelding 1 van 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: stap 2, afbeelding 2 van 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: stap 2, afbeelding 3 van 3
    • Use the Phillips screwdriver size #00 to remove the 1.59mm #00 screws.
    • Remove 2 screws from the side of the camera.
    • Remove 4 screws on the bottom of the camera.
    • Remove 1 screw next to the eyepiece.
  3. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: stap 3, afbeelding 1 van 1
    • Flip the screen back to reveal 2 hidden screws.
    • Remove the two 1.59mm #00 screws on the left with the Phillips #00 screwdriver.
  4. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: stap 4, afbeelding 1 van 1
    • Pull the back panel of the camera upward.
    • Use a spudger to help pry open the back panel.
  5. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: stap 5, afbeelding 1 van 1
    • Open the back panel to view the inside of the camera.
    • If the orange ribbon cable disconnects from its designated port, do not panic. The cable is easy to reinsert.
  6. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: stap 6, afbeelding 1 van 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: stap 6, afbeelding 2 van 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: stap 6, afbeelding 3 van 3
    • Carefully pull out the the eyepiece.
    • Detach the orange ribbon cable that connects it to the green panel by carefully pulling outwards.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
DaQuawn
254 Reputatie
2 handleidingen geschreven
Één opmerking
Thank you very much for the importent articles made for us. If I can please put , how to replace the flasher as well.
Satsara Gunaratne - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 931
