Ga door naar hoofdinhoud
Sony Cyber-shot DSC-HX1 Button Assembly Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: stap 2, afbeelding 1 van 1
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: stap 3, afbeelding 1 van 2 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: stap 3, afbeelding 2 van 2
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
  4. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Button Assembly: stap 4, afbeelding 1 van 1
    • On the top of the inside the battery compartment, remove the #00 6.0 mm Phillips screw.
  5. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: stap 5, afbeelding 1 van 2 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: stap 5, afbeelding 2 van 2
    • Lift the button housing from its position on top of the camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brianna Greenlaw
1.181 Reputatie
5 handleidingen geschreven
Cal Poly, Team 17-3, Forte Spring 2015 Lid van Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 876
