Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide will show you how to remove all the necessary pieces in order to reach and disconnect the LCD screen and replace it.
Wat je nodig hebt
Use the Phillips #00 screwdriver to remove the two screws located on the right side of the camera.
Use the Phillips #00 screwdriver to remove the three screws on the bottom.
Use the plastic opening tool to lift the cover containing the patent information off.
Next, with the same plastic opening tool, stick it in the crack between the metal circle and the black piece on the left.
Once you slide the plastic opening tool in between the crack, slide the black cover and lift it in order for it to be removed.
The first picture shows how the let side of the camera looks once we remove the side piece.
Use the Phillips #00 screwdriver to remove the two screws on this left side.
Flip your camera to the right side where we removed the first two screws.
Use the plastic opening tool into the crack and lift in order to loosen that side of the shell. Loosening one side makes removing the entire shell easier.
Once the side is loose, apply a small amount of force to remove the shell.
After you remove the outer shell, you will see that the green chip, known as the motherboard, is now exposed.
Carefully grab the motherboard and proceed to flip it over.
Grip the ribbon wire coming out of the motherboard as close to the white piece as possible and slightly pull it to disconnect it from the wire.
In order to remove the LCD Screen we separate the metal frame that connects the screen to the camera.
Gently pull the metal frame away, you will notice on the right end the screen is attached by a ribbon wire.
This may be the most challenging step. Slowly remove the metal frame, and eventually it will pop off.
Flip the metal screen over, so that the screen is facing down. You will see a small black clip on the white connector that will allow you to remove the ribbon wire.
Carefully lift the black clip and slide the ribbon out.
The LCD screen should now be removed.
Één andere persoon heeft deze handleiding voltooid.
