Ga door naar hoofdinhoud
Sony Cyber-shot DSC-H200 SD Door Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: stap 1, afbeelding 1 van 2 Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: stap 1, afbeelding 2 van 2
    • Using a screwdriver, remove four 6mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 SD Door Replacement: stap 2, afbeelding 1 van 1
    • Using a screwdriver, remove the two 6mm screws on the bottom.
    • Using a screwdriver, remove the four 3mm screws on the bottom.
  3. Sony Cyber-shot DSC-H200 SD Door Replacement: stap 3, afbeelding 1 van 1
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 SD Door Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-H200 SD Door Replacement: stap 4, afbeelding 2 van 2
    • Using the blue plastic opening tools, remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 SD Door Replacement: stap 5, afbeelding 1 van 2 Sony Cyber-shot DSC-H200 SD Door Replacement: stap 5, afbeelding 2 van 2
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable).
    • Using the blue plastic opening tool remove the LCD Screen from the motherboard.
  6. Sony Cyber-shot DSC-H200 SD Door Replacement: stap 6, afbeelding 1 van 1
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 SD Door Replacement: stap 7, afbeelding 1 van 1
    • Lift the holding plate away from the motherboard and set aside (the pin attaching the door to the body is now accessible).
  8. Sony Cyber-shot DSC-H200 SD Door Replacement: stap 8, afbeelding 1 van 2 Sony Cyber-shot DSC-H200 SD Door Replacement: stap 8, afbeelding 2 van 2
    • Using tweezers remove the pin that attaches the door to the body.
  9. Sony Cyber-shot DSC-H200 SD Door Replacement: stap 9, afbeelding 1 van 1
    • Remove the door.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 16
Altijd: 1,557
