Ga door naar hoofdinhoud
Sony Cyber-shot DSC-H200 LCD Screen Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 3 Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 2 van 3 Sony Cyber-shot DSC-H200 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 3 van 3
    • Using a screwdriver, remove the five 6mm screws located on the back panel.
    • Using a screwdriver, remove the two 3mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Using a screwdriver, remove one 6mm screw on the front panel.
    • Using a screwdriver, remove two 3mm screws on the front panel.
  3. Sony Cyber-shot DSC-H200 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-shot DSC-H200 LCD Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard. (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable.)
  6. Sony Cyber-shot DSC-H200 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 LCD Screen Replacement: stap 7, afbeelding 1 van 2 Sony Cyber-shot DSC-H200 LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • Lift the holding plate away from the motherboard and set aside.
  8. Sony Cyber-shot DSC-H200 LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Using tweezers, open the LCD ribbon port by lifting the black hinge. (The LCD ribbon cable will detach.)
  9. Sony Cyber-shot DSC-H200 LCD Screen Replacement: stap 9, afbeelding 1 van 3 Sony Cyber-shot DSC-H200 LCD Screen Replacement: stap 9, afbeelding 2 van 3 Sony Cyber-shot DSC-H200 LCD Screen Replacement: stap 9, afbeelding 3 van 3
    • Using tweezers, remove the LCD with the ribbon cable and set aside.
Conclusie
Één opmerking
Where can you purchase a new replacement monitor?
Butch Sullivan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 25
Altijd: 2,480
