Ga door naar hoofdinhoud
Sony Cyber-shot DSC-H20 Lens Assembly Replacement
Wat je nodig hebt
  1. Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: stap 1, afbeelding 1 van 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: stap 1, afbeelding 2 van 2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 2, afbeelding 1 van 1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 3, afbeelding 1 van 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 3, afbeelding 2 van 2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 4, afbeelding 1 van 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 4, afbeelding 2 van 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 4, afbeelding 3 van 3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 5, afbeelding 1 van 1
    • Place the camera upside down with the battery port positioned upward and the battery port open.
  6. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 6, afbeelding 1 van 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 6, afbeelding 2 van 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 6, afbeelding 3 van 3
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 7, afbeelding 1 van 1
    • Remove the power shutter unit
  8. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 8, afbeelding 1 van 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 8, afbeelding 2 van 2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
  9. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 9, afbeelding 1 van 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 9, afbeelding 2 van 2
    • Lift up the gray plastic facing in order to uncover the motherboard and the ribbon cable ports.
  10. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 10, afbeelding 1 van 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 10, afbeelding 2 van 2
    • Carefully flip up the three black clasps holding the lens cables to the motherboard.
    • Slide the cables from the ports.
  11. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: stap 11, afbeelding 1 van 1
    • Lift the lens and attached ribbon cables from the camera in order to switch this lens with a new one.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Rachel Payne
392 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-1, Leahy Winter 2015 Lid van USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 33
Altijd: 2,924
