Ga door naar hoofdinhoud
Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement
Wat je nodig hebt
  1. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: stap 2, afbeelding 1 van 1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement, Front and Back Panel: stap 4, afbeelding 1 van 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement, Front and Back Panel: stap 4, afbeelding 2 van 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement, Front and Back Panel: stap 4, afbeelding 3 van 3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: stap 5, afbeelding 1 van 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: stap 5, afbeelding 2 van 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: stap 5, afbeelding 3 van 3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: stap 6, afbeelding 1 van 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: stap 6, afbeelding 2 van 3 Sony Cyber-Shot DSC-W830 Front and Back Panel Replacement: stap 6, afbeelding 3 van 3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
Conclusie
Tong Tang
557 Reputatie
4 handleidingen geschreven
USF Tampa, Team 17-1, Blackwell Fall 2016 Lid van USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 1,135
