Ga door naar hoofdinhoud
Sony Cyber-Shot DSC-W830 Button Board Replacement
Wat je nodig hebt
  1. Sony Cyber-Shot DSC-W830 Button Board Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 Button Board Replacement: stap 2, afbeelding 1 van 1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 Button Board Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: stap 4, afbeelding 1 van 3 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: stap 4, afbeelding 2 van 3 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: stap 4, afbeelding 3 van 3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 Button Board Replacement: stap 5, afbeelding 1 van 3 Sony Cyber-Shot DSC-W830 Button Board Replacement: stap 5, afbeelding 2 van 3 Sony Cyber-Shot DSC-W830 Button Board Replacement: stap 5, afbeelding 3 van 3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 Button Board Replacement: stap 6, afbeelding 1 van 3 Sony Cyber-Shot DSC-W830 Button Board Replacement: stap 6, afbeelding 2 van 3 Sony Cyber-Shot DSC-W830 Button Board Replacement: stap 6, afbeelding 3 van 3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: stap 7, afbeelding 1 van 2 Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: stap 7, afbeelding 2 van 2
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 Button Board Replacement: stap 8, afbeelding 1 van 2 Sony Cyber-Shot DSC-W830 Button Board Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Addyson Salalila
300 Reputatie
2 handleidingen geschreven
USF Tampa, Team 17-1, Blackwell Fall 2016 Lid van USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 19
Altijd: 1,159
