Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
If the lens assembly of your Sony Cyber-Shot DSC-W120 is damaged, this guide will explain how to dissassemble the camera so it can safely be removed.
Onderdelen
Geen onderdelen opgegeven.
  1. Unscrew the screws on the right side of the camera.
    • Unscrew the screws on the right side of the camera.
  2. Using a plastic opening tool, gently lift the side of the silver piece on the right side of the camera until it can be removed. Using a plastic opening tool, gently lift the side of the silver piece on the right side of the camera until it can be removed.
    • Using a plastic opening tool, gently lift the side of the silver piece on the right side of the camera until it can be removed.
  3. Use a plastic opening tool to separate the front case of the camera, and gently remove it. Use a plastic opening tool to separate the front case of the camera, and gently remove it. Use a plastic opening tool to separate the front case of the camera, and gently remove it.
    • Use a plastic opening tool to separate the front case of the camera, and gently remove it.
  4. Use a plastic opening tool to remove the silver piece on the left side of the camera.
    • Use a plastic opening tool to remove the silver piece on the left side of the camera.
  5. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  6. Remove the three screws from the bottom of the camera.
    • Remove the three screws from the bottom of the camera.
  7. Carefully remove the back case with a plastic opening tool. Carefully remove the back case with a plastic opening tool.
    • Carefully remove the back case with a plastic opening tool.
  8. Unscrew the screw just above the mode dial.
    • Unscrew the screw just above the mode dial.
  9. Lift the display from the rest of the camera and gently separate the connecting tape using tweezers.
    • Lift the display from the rest of the camera and gently separate the connecting tape using tweezers.
  10. Separate the tape connecting the lens to the rest of the camera using tweezers. Remove the lens.
    • Separate the tape connecting the lens to the rest of the camera using tweezers.
    • Remove the lens.
  11. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  12. Insert wisdom here.
Conclusie
Dana Sanchez
33 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-5, Leahy Fall 2014 Lid van USF Tampa, Team 1-5, Leahy Fall 2014
USFT-LEAHY-F14S1G5
4 Leden
10 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 980
