Ga door naar hoofdinhoud
Sony Cyber-Shot DSC-W120 Lens Assembly Replacement
Wat je nodig hebt
  1. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement, Lens Assembly: stap 1, afbeelding 1 van 1
    • Unscrew the screws on the right side of the camera.
  2. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 2, afbeelding 1 van 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 2, afbeelding 2 van 2
    • Using a plastic opening tool, gently lift the side of the silver piece on the right side of the camera until it can be removed.
  3. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 3, afbeelding 1 van 3 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 3, afbeelding 2 van 3 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 3, afbeelding 3 van 3
    • Use a plastic opening tool to separate the front case of the camera, and gently remove it.
  4. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to remove the silver piece on the left side of the camera.
  5. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 5, afbeelding 1 van 1
    • Remove the three screws from the bottom of the camera.
  6. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 6, afbeelding 1 van 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 6, afbeelding 2 van 2
    • Carefully remove the back case with a plastic opening tool.
  7. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 7, afbeelding 1 van 1
    • Unscrew the screw just above the mode dial.
  8. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 8, afbeelding 1 van 1
    • Lift the display from the rest of the camera and gently separate the connecting tape using tweezers.
  9. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 9, afbeelding 1 van 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 9, afbeelding 2 van 2
    • Separate the tape connecting the lens to the rest of the camera using tweezers.
    • Remove the lens.
  10. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 10, afbeelding 1 van 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 10, afbeelding 2 van 2
    • Insert wisdom here.
  11. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: stap 11, afbeelding 1 van 1
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dana Sanchez
51 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-5, Leahy Fall 2014 Lid van USF Tampa, Team 1-5, Leahy Fall 2014
USFT-LEAHY-F14S1G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 31
Altijd: 1,584
