Inleiding
This guide is for issues dealing with improper lens operations. It will fix any issues that deal with blurry images, blank images or anything that distorts the picture. This repair will solve any of the problems listed above.
Wat je nodig hebt
Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
Using the tweezers carefully remove the broken/damaged lens with its attached circuit board
Bijna klaar!
Conclusie
