Ga door naar hoofdinhoud
Sony Cyber-Shot DSC-TX9 Flash Replacement
Wat je nodig hebt
  1. Sony Cyber-Shot DSC-TX9 Flash Replacement, Prerequisites Only: stap 1, afbeelding 1 van 3 Sony Cyber-Shot DSC-TX9 Flash Replacement, Prerequisites Only: stap 1, afbeelding 2 van 3 Sony Cyber-Shot DSC-TX9 Flash Replacement, Prerequisites Only: stap 1, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
    • If there is a battery or SD card inside remove before beginning the process.
  2. Sony Cyber-Shot DSC-TX9 Flash Replacement: stap 2, afbeelding 1 van 2 Sony Cyber-Shot DSC-TX9 Flash Replacement: stap 2, afbeelding 2 van 2
    • Use your hands or a Spudger to Pull off the front cover of the camera.
    • If the casing is not coming apart easily, do not force it.
  3. Sony Cyber-Shot DSC-TX9 Flash Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the protective black cover layer with your hands and set it aside.
    • The use of tweezers may be necessary if the cover is difficult to remove.
  4. Sony Cyber-Shot DSC-TX9 Flash Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-Shot DSC-TX9 Flash Replacement: stap 4, afbeelding 2 van 2
    • The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
    • Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
    • DO NOT force the ribbon cables or they will rip.
    • Refer to the (Het herkennen en ontkoppelen van verschillende kabelaansluitingen) page for assistance.
  5. Sony Cyber-Shot DSC-TX9 Flash Replacement, Flash: stap 5, afbeelding 1 van 3 Sony Cyber-Shot DSC-TX9 Flash Replacement, Flash: stap 5, afbeelding 2 van 3 Sony Cyber-Shot DSC-TX9 Flash Replacement, Flash: stap 5, afbeelding 3 van 3
    • Remove the two screws for the metal plate on the bottom.
    • Detach the no fuse ribbon cables by sliding them out.
    • Detach the ZIF connector cables by flipping the small black holder in an upright position and then sliding the cable out carefully.
    • Remove ribbons slowly and carefully or they WILL rip.
    • Screws are of Phillips type, head size Y0 and 0.3 mm in length.
  6. Sony Cyber-Shot DSC-TX9 Flash Replacement: stap 6, afbeelding 1 van 3 Sony Cyber-Shot DSC-TX9 Flash Replacement: stap 6, afbeelding 2 van 3 Sony Cyber-Shot DSC-TX9 Flash Replacement: stap 6, afbeelding 3 van 3
    Koop
    • Carefully remove the Memory card circuit board. You will then be able to see the flash with the capacitors connected.
    • Using tweezers, carefully remove the components. They are all connected together.
    • The circuit board should come out with little force. If it does not, make sure all connections are disconnected.
Conclusie
Yegor Shea
301 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S4-G3, Julie Spring 2017 Lid van UMass Dartmouth, Team S4-G3, Julie Spring 2017
UMASSD-JULIE-S17S4G3
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 317
