Ga door naar hoofdinhoud
Sony Cyber-Shot DSC-TX30 Back Casing Replacement
Wat je nodig hebt
  1. Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 2, afbeelding 1 van 2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 2, afbeelding 2 van 2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 3, afbeelding 1 van 2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 3, afbeelding 2 van 2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Outer Shell: stap 5, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
  6. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 6, afbeelding 1 van 1
    • Using the plastic opening tool, separate the edge-casing from the rest of the camera.
  7. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 7, afbeelding 1 van 2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 7, afbeelding 2 van 2
    • Pull the edge-casing off of the camera.
  8. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 8, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
    • Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
    • Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
  9. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 9, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove one 2 1/2mm screw located near the wrist strap.
  10. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 10, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver remove one black 2 2/5mm screw near the tripod slot on the bottom of the casing.
  11. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 11, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver remove the two 2 2/5mm black screws from the side of the camera opposite of the wrist strap
  12. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 12, afbeelding 1 van 2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 12, afbeelding 2 van 2
    • Using the plastic opening tool, open the device's outer shell.
  13. Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 13, afbeelding 1 van 2 Sony Cyber-Shot DSC-TX30 Back Casing Replacement: stap 13, afbeelding 2 van 2
    • Remove the front casing of the device.
  14. Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Back Casing: stap 14, afbeelding 1 van 3 Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Back Casing: stap 14, afbeelding 2 van 3 Sony Cyber-Shot DSC-TX30 Back Casing Replacement, Back Casing: stap 14, afbeelding 3 van 3
    • Using the plastic opening tool, remove the back casing of the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 883
