Inleiding
When replacing the motherboard of the Sony Cyber-Shot DSC-S90 the process is more simplistic only involving the disassembly of the ribbon cables, casing, and battery terminal. Once these three parts are removed, unclipping the motherboard should happen with ease. The tools required are the plastic opener, and J00 screwdriver.
Wat je nodig hebt
Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
While holding the button downwards, slide the door upwards to unlock and open the door.
Remove the 2mm Phillips #00 screw under the battery port door.
Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the top of the camera.
Release all clips and latches keeping the casing in place using a spudger, opening tool, or screwdriver.
Disconnect the ribbon cables on top of the battery terminal using a spudger or screwdriver.
Disconnect the three pictured ribbon cables using a spudger or screwdriver.
