Ga door naar hoofdinhoud
Sony Cyber-Shot DSC-S90 Front Case Replacement
Wat je nodig hebt
  1. Sony Cyber-Shot DSC-S90 Front Case Replacement, Batteries: stap 1, afbeelding 1 van 2 Sony Cyber-Shot DSC-S90 Front Case Replacement, Batteries: stap 1, afbeelding 2 van 2
    • Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
    • While holding the button downwards, slide the door upwards to unlock and open the door.
  2. Sony Cyber-Shot DSC-S90 Front Case Replacement: stap 2, afbeelding 1 van 1
    • Pull open the door and allow the batteries to fall out.
  3. Sony Cyber-Shot DSC-S90 Front Case Replacement, Back Case: stap 3, afbeelding 1 van 2 Sony Cyber-Shot DSC-S90 Front Case Replacement, Back Case: stap 3, afbeelding 2 van 2
    • Remove the 2mm Phillips #00 screw under the battery port door.
    • Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
  4. Sony Cyber-Shot DSC-S90 Front Case Replacement: stap 4, afbeelding 1 van 2 Sony Cyber-Shot DSC-S90 Front Case Replacement: stap 4, afbeelding 2 van 2
    • Remove the two 2mm Phillips #00 screws (one on each side of the camera).
  5. Sony Cyber-Shot DSC-S90 Front Case Replacement: stap 5, afbeelding 1 van 2 Sony Cyber-Shot DSC-S90 Front Case Replacement: stap 5, afbeelding 2 van 2
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the right side and bottom of the camera with the LCD screen facing you.
  6. Sony Cyber-Shot DSC-S90 Front Case Replacement: stap 6, afbeelding 1 van 1
    • Pull apart the back case from the main body of the camera.
  7. Sony Cyber-Shot DSC-S90 Front Case Replacement, Front Case: stap 7, afbeelding 1 van 1
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the top of the camera.
  8. Sony Cyber-Shot DSC-S90 Front Case Replacement: stap 8, afbeelding 1 van 1
    • Pull apart the front case from the main body of the camera.
Conclusie
Jonathan Arns
745 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team S4-G5, Saloman Fall 2019 Lid van UMass Dartmouth, Team S4-G5, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G5
3 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 265
