Inleiding
When taking off the battery door of the Sony Cyber-Shot DSC-S90, it’s important to remove the battery casing first. After this has been completed, taking off the door should be completed with ease.
Wat je nodig hebt
Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
While holding the button downwards, slide the door upwards to unlock and open the door.
Remove the 2mm Phillips #00 screw under the battery port door.
Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the top of the camera.
