Ga door naar hoofdinhoud
Sony Cyber-Shot DSC-H1 Lens Replacement
Wat je nodig hebt
  1. Sony Cyber-Shot DSC-H1 Lens Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 Lens Replacement: stap 2, afbeelding 1 van 3 Sony Cyber-Shot DSC-H1 Lens Replacement: stap 2, afbeelding 2 van 3 Sony Cyber-Shot DSC-H1 Lens Replacement: stap 2, afbeelding 3 van 3
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 Lens Replacement: stap 3, afbeelding 1 van 2 Sony Cyber-Shot DSC-H1 Lens Replacement: stap 3, afbeelding 2 van 2
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
  4. Sony Cyber-Shot DSC-H1 Lens Replacement, LCD Screen: stap 4, afbeelding 1 van 1
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
  5. Sony Cyber-Shot DSC-H1 Lens Replacement: stap 5, afbeelding 1 van 1
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
  6. Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: stap 6, afbeelding 1 van 2 Sony Cyber-Shot DSC-H1 Lens Replacement, Lens: stap 6, afbeelding 2 van 2
    • Unscrew and remove the gray backing behind the LCD screen.
  7. Sony Cyber-Shot DSC-H1 Lens Replacement: stap 7, afbeelding 1 van 3 Sony Cyber-Shot DSC-H1 Lens Replacement: stap 7, afbeelding 2 van 3 Sony Cyber-Shot DSC-H1 Lens Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using a Phillips #0 screwdriver, unscrew the four 4.24 mm black screws off the blue panel on the right side.
    • Disconnect the white conductive tape.
    • Remove the blue panel.
    • Use tweezers to remove the three conductive tape strips on the right side.
  8. Sony Cyber-Shot DSC-H1 Lens Replacement: stap 8, afbeelding 1 van 2 Sony Cyber-Shot DSC-H1 Lens Replacement: stap 8, afbeelding 2 van 2
    • Use tweezers to remove the orange conductive tape located below the shutter.
    • Unplug the three ZIF connectors from the motherboard.
  9. Sony Cyber-Shot DSC-H1 Lens Replacement: stap 9, afbeelding 1 van 1
    • Flip up the blue overlapping board at the top.
    • Use tweezers to disconnect the remaining connectors.
  10. Sony Cyber-Shot DSC-H1 Lens Replacement: stap 10, afbeelding 1 van 1
    • Remove the motherboard and battery pack unit.
  11. Sony Cyber-Shot DSC-H1 Lens Replacement: stap 11, afbeelding 1 van 3 Sony Cyber-Shot DSC-H1 Lens Replacement: stap 11, afbeelding 2 van 3 Sony Cyber-Shot DSC-H1 Lens Replacement: stap 11, afbeelding 3 van 3
    • Use a screwdriver to remove 5 screws on plastic panel.
    • Remove the single screw on the silver panel in the center.
  12. Sony Cyber-Shot DSC-H1 Lens Replacement: stap 12, afbeelding 1 van 3 Sony Cyber-Shot DSC-H1 Lens Replacement: stap 12, afbeelding 2 van 3 Sony Cyber-Shot DSC-H1 Lens Replacement: stap 12, afbeelding 3 van 3
    • Use tweezers to remove the blue control panel.
    • Remove the lens from the camera.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Charlie Pugeda
505 Reputatie
3 handleidingen geschreven
Baylor, Team S5-G4, Williams Spring 2018 Lid van Baylor, Team S5-G4, Williams Spring 2018
BU-WILLIAMS-S18S5G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 41
Altijd: 1,603
