Ga door naar hoofdinhoud
Sony Cyber-Shot DSC-H1 LCD Screen Replacement
Wat je nodig hebt
  1. Sony Cyber-Shot DSC-H1 LCD Screen Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Power down the camera and remove the batteries.
  2. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: stap 2, afbeelding 1 van 3 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: stap 2, afbeelding 2 van 3 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: stap 2, afbeelding 3 van 3
    • Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
    • There are six 5.22mm long, 3.00mm head diameter screws total.
    • The left side is not shown but there should be 1 screw on that side.
  3. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: stap 3, afbeelding 1 van 2 Sony Cyber-Shot DSC-H1 LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Remove the back casing.
    • The casing itself is sturdy so don't be afraid to remove it forcefully.
  4. Sony Cyber-Shot DSC-H1 LCD Screen Replacement, LCD Screen: stap 4, afbeelding 1 van 1
    • Take a hold of the right side of the LCD screen and lift it towards the left.
    • The screen is held firm and will require a bit of force to ease it from its housing.
  5. Sony Cyber-Shot DSC-H1 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Unplug the large conductive tape attached to the screen.
    • Remove the LCD from the device.
Conclusie
Trystan Jasperson
231 Reputatie
2 handleidingen geschreven
Baylor, Team S5-G4, Williams Spring 2018 Lid van Baylor, Team S5-G4, Williams Spring 2018
BU-WILLIAMS-S18S5G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 672
