Inleiding
The following guidelines will show the step-by-step procedure on how to remove and replace the Sony Clie thumb dial.
Onderdelen
Geen onderdelen nodig.
  1. First, place the device with the screen side facing down. Remove the 2 screws from the thumb dial panel located on the upper right hand side.
    • First, place the device with the screen side facing down. Remove the 2 screws from the thumb dial panel located on the upper right hand side.
  2. Remove the screw  directly above the thumb dial panel.
    • Remove the screw directly above the thumb dial panel.
  3. Remove the screw from thumb dial panel on the right handed side of the device.
    • Remove the screw from thumb dial panel on the right handed side of the device.
  4. Remove screw from lower right side of the device.
    • Remove screw from lower right side of the device.
  5. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  6. Remove 1 screw from the lower left side of the device.
    • Remove 1 screw from the lower left side of the device.
  7. On the bottom of the device, remove both the left and right screws.
    • On the bottom of the device, remove both the left and right screws.
  8. Remove the thumb dial panel by sliding it away from the device.
    • Remove the thumb dial panel by sliding it away from the device.
  9. Remove the back panel exposing the inside of the device.
    • Remove the back panel exposing the inside of the device.
  10. Locate thumb dial on top right side of the board.
    • Locate thumb dial on top right side of the board.
  11. Follow ribbon wire to locate where it plugs into the board.  The plug is a flat black square.
    • Follow ribbon wire to locate where it plugs into the board. The plug is a flat black square.
  12. Pull plug straight up to remove from board.
    • Pull plug straight up to remove from board.
Conclusie
Rob
1 Reputatie
2 handleidingen geschreven
UW Stout, Team 5-6, Zhou Fall 2011 Lid van UW Stout, Team 5-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G6
4 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 943
