Ga door naar hoofdinhoud
Sony Clie PEG-T615C Battery Replacement
Wat je nodig hebt
  1. Sony Clie PEG-T615C Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove two screws from the thumb dial panel on the back of the device.
  2. Sony Clie PEG-T615C Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove one screw from the upper right corner on the back of the device.
  3. Sony Clie PEG-T615C Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove one screw from the thumb dial panel on the right side of the device.
  4. Sony Clie PEG-T615C Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove one screw from lower right side of the device.
  5. Sony Clie PEG-T615C Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove one screw from the lower left side of the device.
  6. Sony Clie PEG-T615C Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove two screws from the bottom of the device.
  7. Sony Clie PEG-T615C Battery Replacement: stap 7, afbeelding 1 van 1
    • Remove the thumb dial panel by sliding it away from the device.
    • You can do this step earlier, after you remove all of the screws from the thumb drive panel.
  8. Sony Clie PEG-T615C Battery Replacement: stap 8, afbeelding 1 van 1
    • Remove the back panel, exposing the inside of the device.
  9. Sony Clie PEG-T615C Battery Replacement: stap 9, afbeelding 1 van 1
    • Remove one screw located on the board below the battery.
  10. Sony Clie PEG-T615C Battery Replacement: stap 10, afbeelding 1 van 1
    • Unplug the male battery plug on the battery wire from the female battery plug on the board.
  11. Sony Clie PEG-T615C Battery Replacement: stap 11, afbeelding 1 van 1
    • Remove the battery by sliding it out of the side of the device.
Conclusie
Rob
1 Reputatie
2 handleidingen geschreven
UW Stout, Team 5-6, Zhou Fall 2011 Lid van UW Stout, Team 5-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G6
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 2,133
