Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the seven screws holding the motherboard to the device.
Unclip the battery harness power cable from the motherboard.
Unclip the scroll wheel power cable from the motherboard.
Pull out the two clips from the center to remove the power cable.
Rotate the motherboard toward you to show the cables on the opposite side of the motherboard.
Extend both sides of the left clip to remove the power cable.
Pull out the center clip to remove the power cable.
The motherboard is removed. To install the new motherboard, follow the directions in reverse.
Één opmerking
I have a full reset whenever I take the battery out to recharge it. Given that all replacement motherboards will be as old as the unit, is there anyway to fix the board (I presume it’s a capacitor or super cell that keeps the charge long enough to swap the battery over normally?). The three cells seem to be soldered onto the board, but I presume could be replaced?
Anyone know of a way to fix this?
