Ga door naar hoofdinhoud
Sony Clie PEG-SL10 Motherboard Replacement
Wat je nodig hebt
  1. Sony Clie PEG-SL10 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Remove the six screws holding the case together.
  2. Sony Clie PEG-SL10 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the seven screws holding the motherboard to the device.
  3. Sony Clie PEG-SL10 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Unclip the battery harness power cable from the motherboard.
  4. Sony Clie PEG-SL10 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Unclip the scroll wheel power cable from the motherboard.
  5. Sony Clie PEG-SL10 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Pull the left clip to remove the cable.
  6. Sony Clie PEG-SL10 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Pull out the two clips from the center to remove the power cable.
  7. Sony Clie PEG-SL10 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Rotate the motherboard toward you to show the cables on the opposite side of the motherboard.
  8. Sony Clie PEG-SL10 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Extend both sides of the left clip to remove the power cable.
  9. Sony Clie PEG-SL10 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Pull out the center clip to remove the power cable.
  10. Sony Clie PEG-SL10 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Pull the right clip out to remove the right cable.
  11. Sony Clie PEG-SL10 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • The motherboard is removed. To install the new motherboard, follow the directions in reverse.
Conclusie
Emily
3 Reputatie
3 handleidingen geschreven
James Madison, Team 1-4, Allen Fall 2011 Lid van James Madison, Team 1-4, Allen Fall 2011
JMU-ALLEN-F11S1G4
3 Leden
4 handleidingen geschreven
Één opmerking
I have a full reset whenever I take the battery out to recharge it. Given that all replacement motherboards will be as old as the unit, is there anyway to fix the board (I presume it’s a capacitor or super cell that keeps the charge long enough to swap the battery over normally?). The three cells seem to be soldered onto the board, but I presume could be replaced?
Anyone know of a way to fix this?
Benjamin S. Leveritt - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 1,346
