Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the six screws holding the case together.
    • Remove the six screws holding the case together.
  2. Remove the seven screws holding the motherboard to the device.
    • Remove the seven screws holding the motherboard to the device.
  3. Unclip the battery harness power cable from the motherboard.
    • Unclip the battery harness power cable from the motherboard.
  4. Unclip the scroll wheel power cable from the motherboard.
    • Unclip the scroll wheel power cable from the motherboard.
  5. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  6. Pull the left clip to remove the cable.
    • Pull the left clip to remove the cable.
  7. Pull out the two clips from the center to remove the power cable.
    • Pull out the two clips from the center to remove the power cable.
  8. Rotate the motherboard toward you to show the cables on the opposite side of the motherboard.
    • Rotate the motherboard toward you to show the cables on the opposite side of the motherboard.
  9. Extend both sides of the left clip to remove the power cable.
    • Extend both sides of the left clip to remove the power cable.
  10. Pull out the center clip to remove the power cable.
    • Pull out the center clip to remove the power cable.
  11. Pull the right clip out to remove the right cable.
    • Pull the right clip out to remove the right cable.
  12. The motherboard is removed.  To install the new motherboard, follow the directions in reverse.
    • The motherboard is removed. To install the new motherboard, follow the directions in reverse.
Conclusie
Emily
1 Reputatie
3 handleidingen geschreven
James Madison, Team 1-4, Allen Fall 2011 Lid van James Madison, Team 1-4, Allen Fall 2011
JMU-ALLEN-F11S1G4
3 Leden
4 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,096
