Ga door naar hoofdinhoud
Sony Clie PEG-NR70 Speaker Rail Replacement
Wat je nodig hebt
  1. Sony Clie PEG-NR70 Speaker Rail Replacement, The Case: stap 1, afbeelding 1 van 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Speaker Rail Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Speaker Rail Replacement: stap 3, afbeelding 1 van 2 Sony Clie PEG-NR70 Speaker Rail Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Speaker Rail Replacement, Speaker Rail: stap 4, afbeelding 1 van 2 Sony Clie PEG-NR70 Speaker Rail Replacement, Speaker Rail: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
    • Be careful not to tear the speaker wires! They are very thin.
    • Remove the tape holding speaker wire by peeling it away.
  5. Sony Clie PEG-NR70 Speaker Rail Replacement: stap 5, afbeelding 1 van 1
    • Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
    • Remove the speaker rail vertically from the device.
Conclusie
Daniel Soski
57 Reputatie
6 handleidingen geschreven
Cal Poly, Team 14-11, Maness Spring 2013 Lid van Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 313
