Ga door naar hoofdinhoud
Sony Clie PEG-NR70 Battery Pack Replacement
Wat je nodig hebt
  1. Sony Clie PEG-NR70 Battery Pack Replacement, The Case: stap 1, afbeelding 1 van 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Battery Pack Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Battery Pack Replacement: stap 3, afbeelding 1 van 2 Sony Clie PEG-NR70 Battery Pack Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: stap 4, afbeelding 1 van 2 Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: stap 4, afbeelding 2 van 2
    • Pull up on the black tab on the battery pack to reveal the power cord.
  5. Sony Clie PEG-NR70 Battery Pack Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the battery pack from the motherboard by unplugging the power cables. Gently pull the wire toward the bottom of the device.
    • Be careful to not tear the cables! They are very thin.
  6. Sony Clie PEG-NR70 Battery Pack Replacement: stap 6, afbeelding 1 van 1
    • Gently peel back the adhesive to completely disconnect the battery pack from device.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Courtney
49 Reputatie
2 handleidingen geschreven
Cal Poly, Team 14-11, Maness Spring 2013 Lid van Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Leden
8 handleidingen geschreven
Één opmerking
Hi, this is really helpful, thank you.
Richard Hancock - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 32
Altijd: 2,230
