Inleiding
If your device is not holding a charge or simply will not turn on, it is possible that you need to replace the battery. This easy guide will take you through the necessary steps in order to remove the battery so you may install a new one.
Wat je nodig hebt
Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
3 andere personen hebben deze handleiding voltooid.
